Seagate Constellation ES.2 ST33000650NS - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Seagate Think Green, PowerChoice
10.2 cm x 14.7 cm x 2.6 cm
0.7 kg
Microsoft Certification
Compatible with Windows 7
5-year warranty
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
512
10.2 cm
14.7 cm
2.6 cm
0.7 kg
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
155 MBps
Seek Time
8.5 ms (average)
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance
70 g @ 2ms (operating) / 300 g @ 1ms (non-operating)
