Back
Internal Hard Drives
Seagate 2TB Barracuda SATA 6Gb/s 64MB 3.5" 7200RPM Internal Drive
Quicklinx:
CBLGWS00
Mfr#:
ST2000DM006
Gallery
Back
This HDD for all your PC needs brings you outstanding excellence in personal computing.
Versatile
Get an HDD for all your PC needs that brings you outstanding excellence in personal computing.
Advanced power
Advanced power helps save energy without sacrificing performance.
Seagate Barracuda ST2000DM006 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, TGMR recording technology, advanced format 512e, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.11 mm
626 g
2 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
626 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Seek Time
8.5 ms (average)
Track-to-Track Seek Time
1 ms
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
8 watt (active) , 5.4 watt (idle) , 0.75 watt (standby) , 0.75 watt (sleep)
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
80 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
