The Sapphire HD 3450 AGP brings the features of the highly acclaimed HD 3000 series to the users of older PC systems with the AGP graphics bus. In addition to dramatically increased graphics performance, this means support for all the latest generation of games with DirectX 10.1 and the ability to smoothly play HD and Blu-Ray DVD's with the built-in hardware UVD decoder. It also allows users to accelerate tasks such as video transcoding (converting video formats to play on portable devices) and other new applications supporting AMD Stream technology.
- 64-bit DDR2 memory interface
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- 32-bit floating point texture filtering
- 2 Years Manufacturers Warranty
- AGP based PC is required with one 4X/8X AGP slot available on the motherboard
- 300 Watt or greater power supply is recommended with one 6 pin power connector
- Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
- 1GB of system memory recommended
- Installation software requires CD-ROM drive
- DVD playback requires DVD drive
- Blu-ray playback requires Blu-ray drive and full 1080p display requires a 1080p-capable monitor
- Warranty: 2 Years Manufacturers Warranty
