The SAPPHIRE R7 240 with Boost now has the latest DDR3 memory clocked at 1800MHz effective, and runs with a core clock speed of 730 MHz which with PowerTune Dynamic Boost rises to 780 MHz on the engine.
Specification
- Display Support 2 x Maximum Display Monitor(s) support
- Output D-Sub(VGA), 1 x HDMI (with 3D), 1 x Dual-Link DVI-D
- GPU 730 MHz Core Clock, 28 nm Chip, 320 x Stream Processors
- Video Memory 2048 MB Size, 128 -bit DDR3, 1800 MHz Effective
- Dimension 145(L)X95(W)X15(H) mm Size, 2 x slot
- Software Driver CD, SAPPHIRE TriXX Utility
