The SAPPHIRE R7 240 1GB with Boost now has the latest GDDR5 memory clocked at 4600MHz effective, and runs with a core clock speed of 730 MHz which with PowerTune Dynamic Boost rises to 780 MHz on the engine.
Specification
- Display Support 2 x Maximum Display Monitor(s) support
- Output D-Sub(VGA), 1 x HDMI (with 3D), 1 x Dual-Link DVI-D
- GPU 730/Boost:780 MHz Core Clock, 28 nm Chip, 320 x Stream Processors
- Video Memory 1024 MB Size, 128 -bit GDDR5, 4600 MHz Effective
- Dimension 150(L)X105(W)X15(H) mm Size, 1 x slot
- Software Driver CD
