The XD2200 provides "Auto Setup Function" that corrects vertical shape distortion by searching for an input signal and detecting projector incline, reducing setup time. Furthermore, the "Screen Guidance Function" allows projector set up according to the displayed guidance. This function provides all an easy guide to projection. This model is equipped with Wired LAN (RJ-45) that allows you to manage and control projector via Network. It is possible to check the operating time of lamp and manage the warning notification by Email. Power ON/ OFF and switching of input signal can be controlled. You can save a lot of time about manage and control. *Images cannot be transmitted via network
