            The Sanus VuePoint F55c is a superior wall mount solution for most 47" - 80" flat-panel TVs up to 130 lbs. Its ultra low-profile design sits just 1" from the wall to maximize the sleek, thin look of the TV. Brackets easily shift left and right on the wall plate to allow perfect TV placement, even with off-center wall studs. A quick latching mechanism holds the TV securely on the wall for added safety. The F55b is pre-assembled and is easily installed in minutes. Solid construction is strong and durable.
