            The Sanus VuePoint F180c is a versatile full-motion wall mount solution for most 47" - 70" flat-panel TVs. Its full range of movement allows smooth extend, tilt, swivel and roll motions up to 15" from the wall without the use of tools. The F180c tilts +11º/-12º with the touch of a finger, making it easy to reduce glare. Cable management tie clips conceal and organize cables the length of the mount for a seamless appearance. Lateral shift ensure perfect TV placement, even with off-center wall studs.
