Compact Design for Maximum Portability
The Cruzer Blade USB flash drive features a compact design that fits easily into a pocket or computer bag. This USB drive has a sleek black and red design that coordinates with many electronic devices.
High-Capacity Drive Accommodates Your Favorite Media Files
Designed by SanDisk, a USB in flash memory innovation, the Cruzer Blade USB flash drive packs generous capacity into a compact form. Available in sizes up to 32GB, this USB drive can hold all your must-have files.
Simple Drag-and-Drop File Backup
Transferring data onto the Cruzer Blade USB flash drive is easy: simply plug it into your computer's USB port and drag files into the drive's folder. After a fast, first time driver download, this USB drive lets you start storing, transporting, and sharing your data immediately.
SanDisk SecureAccess Software Protects Drive from Unauthorized Access
The Cruzer Blade USB flash drive comes with the exclusive SanDisk SecureAccess , which creates a password-protected private folder on your flash drive. SanDisk SecureAccess software uses 128-bit AES encryption, so you'll be able to share the files you want while keeping your private files locked.
Includes 2GB of Cloud Storage Offer from YuuWaa
The Cruzer Blade USB flash drive includes free access to 2GB of online storage offered by YuuWaa, a cloud storage service that syncs with your USB drive. Thanks to a user-friendly drag-and-drop interface, it's easy to transfer files from your drive to a secure YuuWaa server for safe online backup.
Warranty
The Cruzer Blade USB Flash Drive is backed by a two-year limited warranty
