With a read rate of 400 MB/s, the SanDisk Creator allows for rapid access to files, enhancing productivity and minimizing wait times during transfers.
Generous storage capacity
Offering 512 GB of storage space, this USB flash drive ensures ample room for documents, photos, videos, and other important data.
Convenient portability
Equipped with a key ring loop, the drive can easily be attached to keychains, bags, or lanyards, allowing for quick and convenient access to files on the go.
Robust compatibility
The SanDisk Creator features a USB-C 3.2 Gen 1 interface, ensuring fast and reliable connections with a wide range of devices.
Reliable operating conditions
Designed to function optimally in temperatures ranging from 0°C to 45°C, ensuring that the drive can operate effectively in varied environments.
SanDisk Creator - USB flash drive - 512 GB
USB flash drive
Interface Type
USB-C 3.2 Gen 1
Storage Capacity
512 GB
Software Included
Adobe Photoshop Lightroom (3 months trial)
Android 8.0 (Oreo) or later, Apple MacOS 12.0 or later, Microsoft Windows 10 or later
5-year warranty
USB flash drive
Storage Capacity
512 GB
Read Rate
Up to 400 MB/s
Interface Type
USB-C 3.2 Gen 1
Key ring loop
Software Included
Limited warranty - 5 years
16 mm
45.8 mm
11.8 mm
10.8 g
Shipping Width
13.4 mm
Shipping Depth
101.6 mm
Shipping Height
152.4 mm
45 °C
