This DVI-D Single-Link cable allows you to connect a DVI screen digitally with a maximum resolution of 1920 x 1080. The cable is double-shielded and uses ferrite cores to suppress noise and ensure optimum image quality. Note that this cable cannot be used to transmit analog VGA signals.
