Quicklinx: | B2YLWS00 |
Mfr#: | SL-M2885FW/SEE |
No more waiting. Samsung's high-performance Xpress M2885FW multi-function printer delivers great results while cutting costs. Print wirelessly and share effortlessly with the Samsung Xpress M2885FW. All it takes is a simple tap with its advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. Simply tap your NFC-enabled mobile device to the Samsung Xpress M2885FW to quickly and easily establish a Wi-Fi direct connection, so you can print virtually any content from your smartphone or tablet.
