Enable your printer or MFP to join your Wi-Fi network for improved workflow opportunities. Active Near Field Communication (NFC) allows you to easily connect a smartphone or tablet to the device via Wi-Fi or Wi-Fi Direct by simply tapping in. The added feature of secure print authentication will help to ensure that sensitive documents are protected from unauthorized use.
