From up close or far away, preserve the moment exactly how you want to remember it. Capture a spectacular mural that takes up the entire side of a building or a field of colorful wildflowers that seems to stretch for miles-with the 24 mm wide-angle lens. When you can't get physically closer to your subject, such as a windsurfer sailing across the sea, the 12x optical zoom lets you capture every sharp detail.
Tiny sensors tend to lead to noisy pictures. The WB35F, however, comes equipped with a 16-megapixel CCD sensor that's larger-1/2.3", to be exact-than those found in most compact digital cameras. The results are vivid yet natural images, whether you're shooting in a dimly lit room or outside on a sunny day.
