Choose a more convenient way to access your data on the move. This Samsung optical disc drive (ODD) is ultra slim, so it's easy to take with you wherever you go. It's compatible with all Samsung notebooks, too, and the data connection and power are delivered via only one simple USB cable as well. This means you can use it on the move without searching for power outlets.
