Using an advanced quality improvement algorithm, Samsung's Wide Color Enhancer drastically improves the quality of any image and uncovers hidden details. Now see colors as they were meant to be seen with Wide Color Enhancer.
Bringing a full multimedia experience into your living room
With High Definition Multimedia Interface (HDMI) inputs, the Samsung TV will transform your living room into a multimedia entertainment center. HDMI provides high-speed transmission of high definition digital data from multiple devices straight into your TV.
Watch movies from your USB
With ConnectShare Movie, simply plug your USB memory drive or HDD into the TV and instantaneously enjoy movies, photos or music. Now, you can experience a wide variety of content in the comfort of your living room on your TV.
Samsung UE32J4100AK 4 Series - 32" LED-backlit LCD TV - HD
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Frame Rate & Enhancement Technology
100 Picture Quality Index
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, DTS Premium Sound 5.1
USB
Samsung TM1240A remote control, batteries
Voltage
AC 230V
Energy Class
Class A+
54 Watt
Power Consumption (On mode)
31 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
45 kWh
73.61 cm x 6.29 cm x 44.74 cm
4.5 kg
LED-backlit LCD TV
Energy Class
Class A+
54 Watt
31 W
45 kWh
Diagonal Class
32"
Series
4 Series
TV Tuner
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Game mode, Film Mode, Sports mode
Design
T-shape Design
Dimensions
Without stand
73.61 cm
6.29 cm
44.74 cm
4.5 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
LED backlight
HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, Digital Clean View, E-Manual, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
HDTV Tuner
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Samsung TM1240A
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Connect & Share
ConnectShare
Connector Type
2 x HDMI , USB 2.0 , Headphones , Composite video / component video input , Audio line-in , Digital audio output (optical) , SCART
Batteries
EU Ecolabel, Eco Mark
Power supply
Input Voltage
AC 230V
0.3 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 73.61 cm x 6.29 cm x 44.74 cm x 4.5 kg , Panel with stand - 73.61 cm x 15.1 cm x 48.87 cm x 4.8 kg
