The beauty in simplicity
Enjoy the sleekness of the Galaxy Tab S7 FE 5G in your hands. The simple, unibody design looks refined with the minimal camera housing on the rear, and the slim form factor keeps your grip comfortable.
Enjoy the immersive sights and sounds
Take in the vibrant colors of Galaxy Tab S7 FE 5G's 12.4" display. The vibrant screen lets details shine, and the cinematic experience is enhanced with the incredible sound by AKG.
Level up your gaming - or your productivity
Equipped with a high-performing Snapdragon 750G chipset, Galaxy Tab S7 FE 5G keeps your streaming and gaming smooth and fast. You can multitask with ease and launch up to three apps all at once.
Connect, download and enjoy, 5G
5G connectivity changes the game - and your work. Incredible speeds let you download in a flash, and low latency keeps your connection strong with little lag. Stay one step ahead on the next-generation data network and discover ways of sharing and experiencing content online.
The battery to take on your busy days
Hours and hours will go by before you have to charge up the 10,090 mAh (typical) battery. It lasts longtime when you're watching videos, giving you plenty of time for a streaming marathon. And with 45 W super fast charging, you can get back to full charge quick.
Stay clear and center on camera
Turn your Tab to landscape mode for a video call and the relocated front camera keeps you in the center of the screen. When you're talking, your voice comes through clearly with the 3 microphones embedded around the display.
Be your most productive with Samsung DeX
Samsung DeX gives you access to your apps and files and lets you open things easily through the intuitive, simplified task bar. The App order layout syncs up with your App screen so you quickly find the app you want.
Making the most of your multitasking
Multiply your screens with the enhanced multitasking experience on Galaxy Tab S7 FE 5G. App Pair allows you to launch up to three apps at once - all you have to do is set it up on the Edge panel. These apps can be custom arranged to your specific needs, even with multiple instances of the same app.
Move from device to device without missing a thing
Sync up Galaxy Tab S7FE56 to a seamless multi-Galaxy experience. Move websites between devices or copy text on your tablet and paste it on your phone. If you get a call while watching a movie, Galaxy Buds automatically connect to your phone and then switch back to your tablet when you're done.
Web browsing over 4G: up to 12 hour(s) , Web browsing over Wi-Fi: up to 12 hour(s) , Video playback: up to 13 hour(s) , Audio playback: up to 201 hour(s) , Talk time: up to 71 hour(s)
Mystic pink
Sensors
Accelerometer, ambient light sensor, gyro sensor, hall sensor, geomagnetic sensor
MU-MIMO technology, fast charging, tuned by AKG speakers, Samsung DeX
