As entertainment content becomes more available, the need for hardware technology to maintain increasing volumes of software content becomes more important. Combining this 3D technology with Samsung's LCD monitor creates an optimal viewing tool - for uses ranging from teaching and using 3D modeling to playing the latest video games.
Tired of living in a 2D world? Upgrade your PC to a fully immersive stereoscopic 3D gaming experience with NVIDIA® GeForce® 3D Vision™ and Samsung® SyncMaster™ 2233RZ 120Hz LCD. GeForce 3D Vision is a combination of high-tech wireless glasses (available seperately) and advanced software that transforms hundreds of PC games, 3D movies, and digital photographs into an eye popping, interactive experience.
High Tech Design
Custom engineered, active LCD shutter glasses with built-in electronics were designed to pair with 120Hz LCD displays like the Samsung SyncMaster 2233RZ.
Unmatched Comfort and Style
Wireless 3D glasses, designed after modern sunglasses, are comfortable, lightweight, and fully adjustable.
Instant immersion
Automatic installation, device detection, and setup get you into the action in minutes, with support for hundreds of DirectX® games.
Blazing fast LCD 120 Hz refresh rate
120Hz refresh and low GtG time deliver superior response times for gaming, giving GeForce gamers a competitive edge. Until now, gaming enthusiasts looked to CRT technology for absolute fastest response-times and immediate feedback which traditional LCD monitors could not deliver.
Gaming realism like never before
With frame rates up to 120fps, Samsung 120Hz LCD monitors provide a gateway to new levels of visual quality and realistic motion like never before. Plus, 120Hz pushes the maximum realizable frame rate so you can get the most of your GeForce graphics performance.
Convert standard games into stereoscopic 3D
Advanced NVIDIA software automatically converts over 350 games to stereoscopic 3D without the need for special game patches.
Highest quality stereoscopic 3D solution
High tech active shutter glasses, designed with top-of-the-line optics deliver 2X the resolution per eye and ultra-wide viewing angles.
Support for new pure 120 Hz LCD monitors
Unlocks crystal-clear, flicker-free stereoscopic 3D gaming, enabling 60 Hz per eye.
Maximum 3D Ready display flexibility
Designed for DLP® 1080p HDTVs, pure 120 Hz LCD monitors, and DepthQ HD 3D projectors, unlocking crystal-clear, flicker-free stereoscopic 3D gaming and multiple viewing solutions.
Designed for comfort and style
Comfortable to wear and modeled after modern sunglasses, offering a stylish and lightweight alternative to traditional 3D glasses.
Wear over your prescription glasses
Ensures that users with corrective eyewear can view fully immersive stereoscopic 3D. In addition, adjustable nose pieces ensure a custom fit for each user.
High power wireless infrared communication
Fully untethered solution, offering free range of motion and up to 15 feet of wireless 3D viewing via infrared communication. And multiple users can use the same IR receiver for a multi-user experience.
Game for more than forty hours on a single charge
Easily recharge your 3D glasses over a standard USB cable without frequently replacing batteries, and game for an entire week without needing to recharge your glasses. Intelligent circuit design automatically shuts off after 10 minutes when not in use to preserve battery life.
Adjust 3D depth adjustment from the IR emitter
Allows you to quickly and easily control common stereoscopic 3D functions without searching for hotkeys.
Watch movies in 3D
Fully supports 3D video players such as 3dtv Stereoscopic Player, allowing you to view fullscreen 3D movies. Futureproof your system for the next generation high definition 3D movie formats with superb high definition video playback on GeForce GPUs.
Instant Immersion
Get into the action in minutes with automated set-up; finger controlled 3D depth adjustment, and instant display detection.
Stereoscopic 3D picture support
Easily take in-game screenshots and view them in stereoscopic 3D with NVIDIA's free photo viewer. In addition, import and view stereoscopic pictures from a variety of different capture sources.
Powered by NVIDIA GeForce GPUs
The #1 choice of PC gamers worldwide, enabling rich, immersive games with stunningly accurate realism thanks to support for the latest graphics technologies including NVIDIA SLI® technology, NVIDIA PhysX™, and DirectX® 10.
Highlights of the Samsung 22" SM2233RZ monitor
Screen: 22" widescreen (1680 x 1050)
Brightness: 300 cd/m2
Contrast Ratio: 20000:1 (Dynamic)
Response time: 2D = 5ms 3D = 3ms
Maximum refresh rate: 120 Hz
Connectivity: DVI, VGA (HD-15)
Vesa Wall mount (100mm)
nVidia 3D Glasses available to purchase seperately - Type Quicklinx 5JRV into the search bar
