Know when there’s a water leak in your home.
- Know when there’s a water leak in your home.
- Receive alerts when moisture is detected.
- Set connected devices to turn on or off when moisture is detected.
- Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Water Leak Sensor. Receive alerts or set connected devices to turn on or off when moisture is detected. Also monitors temperature.
SmartThings is the easy way to turn your home into a smart home.
- Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
- Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
- Finally, use the Google Assistant, Amazon Alexa, or the SmartThings app to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home.
In the Box
- SmartThings Water Leak Sensor.
- Battery
- Quick-start guide and health and safety guide.
Requirements
- Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
- Visit SmartThings.com for specifications, support, and more.
Technical Information
- Power: 1 x CR2 battery.
- Communication Protocol: Zigbee.
- Range: 15-40 meters depending on your home’s construction.
- Operating Temperature: 0 to 40°C.
- Dimensions: 58.9 x 41.9 x 20 mm.
- Weight: 49.9 grams.
- Color: White.
- Warranty: One-year limited warranty.
