Know when doors and windows are opened or closed.
- Know when doors and windows are opened or closed.
- Receive alerts if windows open unexpectedly.
- Set connected lights to turn on and off as you open doors, windows, and cupboards.
- Monitor temperature and vibration.
- Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Multipurpose Sensor. Receive alerts if windows open unexpectedly, set connected lights to turn on and off as you open doors, and much more. Also monitors temperature and vibration.
SmartThings is the easy way to turn your home into a smart home.
- Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
- Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
- Finally, use the Google Assistant, Amazon Alexa, or the SmartThings app to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home.
In the Box
- SmartThings Multipurpose Sensor (2 parts).
- Battery, mounting pads, screws, and bracket.
- Quick-start guide and health and safety guide.
Requirements
- Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
- Visit SmartThings.com for specifications, support, and more.
Technical Information
- Power: 1 x CR-2450 battery.
- Communication Protocol: Zigbee.
- Range: 15-40 meters depending on your home’s construction.
- Operating Temperature: 0 to 40°C.
- Dimensions: 43.7 x 51.8 x 13.7 mm.
- Weight: 40.8 grams.
- Color: White.
- Warranty: One-year limited warranty.
