2M (Full HD) SNH-E6440Bn camera helps you to monitor a clearer and brighter video. The visual angle of 128 degrees can provide wide monitoring coverage for your camera. If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area.
You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network.
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
The product is water/vibration proof (IP66), and it can be installed in an outdoor area or outside the home.
