There is never been an easier way to make a call when you are on the move. You can place and answer calls, or even record a voice memo, directly from your Samsung Galaxy Gear. It is the simple way to keep up when you have a lot going on.
A more intelligent way to interact
When you get a notification on your Galaxy Gear that requires a more in-depth look, the moment you pick up your Galaxy phone, smart relay automatically opens the app that corresponds with what is on your wrist.
Lock it down
No need to worry about keeping your sensitive information private. Auto lock is easy to set up, and intuitively senses when you have walked more than five feet away from your Galaxy Note 3, then automatically secures your phone for you. And when you return, your phone is automatically unlocked - no PIN required.
