If you're looking for a versatile print solution that offers high performance, financial savings and eco-friendliness, choose the Samsung SCX-4729FW Mono Laser Multifunction Printer. You can print, scan, copy and fax without needing several costly and space-intensive devices. Fast Speed printing makes sure your demands are met, thanks to the fast 533MHz processor and 128MB of memory. Duplex printing capabilities allow you access to a diverse range of single and double-sided formats that can reduce your paper costs and environmental impact. You can also make eco and cost savings with Eco Mode, activated quickly with the convenient Eco Button, which optimises usage of energy and supplies.
