Samsung printers are compactly designed, offering a stylish look that's compatible with all small office and home office working environments. This robust and durable model is reliable even in the most intensive office environments. Low noise levels are an added advantage with reduced interference and vibration in your workplace, therefore avoiding any unnecessary distractions.
This device uses enclosed 250-sheet paper input cassettes that reduce user intervention and the need to frequently replenish paper. Selecting Toner Save Mode allows you to use less toner on each page. This extends toner cartridge life by up to 30%, reduces your cost-per-page, lowers user intervention and helps to meet environmental standards.
Not only does the ultra-versatile SCX-4623FW let you print, scan, copy, and fax, it connects you to your wireless network with its one-touch Wi-Fi setting button.
