The Samsung DeX Station enables you to turn your Galaxy S8 or Galaxy S8+ into a true desktop PC experience. By docking the Galaxy S8 or Galaxy S8+ into the DeX Station, your phone will launch a special DeX mode on the connected external monitor and applications can be opened in multiple separate windows. Connect a mouse, keyboard, and Ethernet cable for the full experience.
Multi-tasking Made Easy Simply connect your Samsung to a keyboard and mouse and get started. You are able to open up multiple windows to complete several tasks at once.
Present your Phone onto a Larger Screen No need to boot up - Simply connect and go. The DeX station supports Galaxy S8/S8+
Desktop Experience Multitask with the ease of a desktop environment using your Galaxy S8 or S8+ to access files, edit documents, and even stream videos.
Seamless Switching Instant access to everything on your phone when you connect to the DeX station, from everyday apps to important documents. The Galaxy S8/S8+ can handle desktop duties due to the powerful 10nm AP Processor.
Samsung DeX Station EE-MG950 - docking station - USB-C - HDMI
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI
10.52 cm x 4.75 cm x 10.52 cm
231.07 g
Galaxy S8, S8+
Docking station
10.52 cm
4.75 cm
10.52 cm
231.07 g
Enclosure Colour
1 x audio / video - HDMI - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB-C - 24 pin USB-C , 1 x network - Ethernet - RJ-45 , 1 x power - 24 pin USB-C (power only)
