A natural fit for your eyes with a curvature of 3,000 R, delivering a wider field of view that's easy on the eyes for a more comfortable viewing experience. Experts have found that people perceive curves as more visually comforting than hard lines and angles. Simply viewing the curves of an object triggers relief in the brain.
More vivid than conventional monitors to provide truly brilliant pictures with deeper blacks, pristine whites, amazingly bright colors, and less light leakage.
More vivid and brilliantly clear with the highest brightness level of 350 cd/sq m enables you to see every intricate detail. Wide viewing angle: delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle.
With thoughtful design and engineering, the SE590C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it's carefully designed to keep the focus on your content viewing pleasure.
