The ergonomics of the SD850 helps make your professional work space convenient and comfortable. Samsung's height adjustable stand (HAS) design lets you adjust the monitor height by up to 130mm. You can pivot, swivel, and tilt to adjust the perspective from horizontal to vertical. It even supports Auto OSD Rotation so you don't have to change the aspect ratios when you want to pivot your screen.
The SD850 features a bezel that helps provide a deeply immersive viewing experience that lets you concentrate on the tasks at hand.
View from various angles with the SD850. The Samsung LED Monitor has a wide viewing angle, vertically and horizontally.
With Picture-by-Picture (PBP), you can connect two compatible PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the WQHD resolution size you won't have to worry about losing the picture quality and resolution. Plug in your compatible laptop and your desktop and use both without needing to keep looking between different monitors - it's all there at a glance.
Samsung's latest Picture-in-Picture 2.0 technology lets you multi-task and watch videos. Whether it's 720p or 480p, PIP 2.0 doesn't downscale contents and helps maintain the same resolution as clear and crisp on its own. It supports resolutions up to HD and you can adjust the PIP resolution and position to help fit your needs.
The SD850's light sensor adjusts the screen brightness to help match your environment so that the screen is visible in a range of lighting conditions.
