MagicBright, game mode, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
55.48 cm x 22.4 cm x 38.73 cm - with stand
5.8 kg
VGA , DVI , DisplayPort 1.2 , 2 x USB 2.0
Mechanical
Display Position Adjustments
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Input Voltage
AC 120/230 V
Power Consumption (On mode)
17 W
17 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption (Max)
35 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 55.48 cm - depth: 22.4 cm - height: 38.73 cm - weight: 5.8 kg , Without stand - width: 55.48 cm - depth: 5.51 cm - height: 35.94 cm - weight: 4.11 kg
Shipping Width
62.8 cm
Shipping Depth
43.3 cm
Shipping Height
18.8 cm
Shipping Weight
7.32 kg
10 °C
10 - 80% (non-condensing)
