Mega Dynamic Contrast Ratio delivers a mega experience. Make a difference with new Eco saving modes. Get comfortable with a wider viewing angle thanks to Magic Angle. Make an impression with the new slim and modern design monitor.
With its high-gloss black finish and clean lines, this monitor has a sophisticated and modern design that is sure to make an impression.
Upscale your view with better quality
Magic Upscale technology enhances the image quality no matter what the original picture quality was. Magic Upscale prevents image degradation when scaling up and gives only the most brilliant and pristine colors and images.
Experience real color with mega DCR
Mega Dynamic Contrast Ratio delivers enhanced levels of color and picture quality to your viewing experience with images that are real-to-life. Mega DCR's contrast ratio shows blacks at their absolute darkest and whites and colors at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity.
Less power consumption, conserve energy
Eco saving makes saving energy easy. The brightness of the monitor can be adjusted based on how much energy you want to save. And with the choice of three energy saving modes: 50%, 25% and power saving off, you can tailor your monitor use to meet your own personal needs.
See it clearer with wider viewing angles
Enjoy the most comfortable viewing experience with Samsung's magic angle. This feature centers the image and eliminates distortion to provide amazing picture clarity whether standing, sitting, or even lying down.
Samsung S24D300HL - SD300 Series - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
TN
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
700:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Voltage
Black lacquer
56.9 cm x 19.7 cm x 41.72 cm
3.55 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
23.6"
Panel Type
TN
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
Black lacquer
56.9 cm x 19.7 cm x 41.72 cm - with stand
3.55 kg
VGA , HDMI
1 x VGA cable
Power Supply
External
Input Voltage
20 W
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.72 cm - weight: 3.55 kg , Without stand - width: 56.9 cm - depth: 5.39 cm - height: 34.21 cm - weight: 3.2 kg
