Samsung AD-PLS panels deliver 178° viewing angles for a wide point of view at a cost-competitive price point. Enjoy outstanding image quality with a sharp, clear picture even when viewed from off angles for greater convenience and versatility.
More connectivity options
VGA, HDMI and DisplayPort give users flexibility in high-speed connectivity, offering connection capability with a wide range of devices. So whatever device you need to connect to today or in the future, the SC650 series keeps your options open.
Built-in speakers
Integrated 2-way speakers provide outstanding stereo sound for an enhanced multimedia experience whether watching movies, listening to music or catching online news segments. Enjoy quality audio and a crisp, clear sound for your listening pleasure.
LED technology saves energy
Samsung's LED technology and user-adjustable brightness settings enable enterprises to better manage power usage and reduce energy consumption by up to 50% as compared to traditional CCFL. Control costs and leave a light environmental footprint.
Samsung S24C650BW - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Panel Type
AD-PLS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Voltage
Matte black
55.48 cm x 22.4 cm x 38.2 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Display Type
Energy Class
Class B
50 kWh
Diagonal Size
24"
Panel Type
AD-PLS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicRotation, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
Matte black
55.48 cm x 22.4 cm x 38.2 cm - with stand
5.7 kg
VGA , DVI
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
Input Voltage
34 W
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.1 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 55.48 cm - depth: 22.4 cm - height: 38.2 cm - weight: 5.7 kg , Without stand - width: 55.48 cm - depth: 5.42 cm - height: 35.935 cm - weight: 4.1 kg
