Business monitors can be stylish as well as efficient. Your Samsung LED business monitor is designed with a very narrow bezel width, which delivers both better viewing and a more attractive look. It's compact, space-saving form will also help you to make the most of your working environment. You can also wall-mount it easily and achieve the best possible positioning. Thanks to Magic Angle technology, you'll enjoy a great visual experience from a wide range of viewpoints. The monitor even helps you reduce energy costs, as it consumes just 0.1 W while in standby mode.
