Samsung S22C150N - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
200 cd/m²
Contrast Ratio
700:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
High glossy black
51.2 cm x 19.7 cm x 38.5 cm
3.1 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
200 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
148 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
High glossy black
51.2 cm x 19.7 cm x 38.5 cm - with stand
3.1 kg
VGA
Mechanical
Tilt
1 x VGA cable
Power Supply
External
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 51.2 cm - depth: 19.7 cm - height: 38.5 cm - weight: 3.1 kg , Without stand - width: 51.2 cm - depth: 5.3 cm - height: 31.1 cm - weight: 2.7 kg
