Samsung's QMR series displays cut through the clutter to deliver advanced Ultra HD resolution as well as intelligent Ultra HD upscaling and rich flawless colors with Dynamic Crystal Color all in a slim design.
Samsung's QMR series provides ultra-high-definition 4K resolution, creating lifelike images with sharper picture quality than ever before.
Intelligent Ultra HD upscaling
Samsung's cutting-edge intelligent Ultra HD upscaling technology performs edge restoration and noise reduction to deliver perfect Ultra HD picture quality even with lower resolution content. This "future-proof" solution ensures excellent picture quality regardless of the original content resolution.
The QMR series features Dynamic Crystal Color, using 10-bit processing for flawless color expression, allowing viewers to enjoy a wider spectrum of colors up to one billion shades. HDR+ functionality converts standard definition content to HDR quality for sharper contrast and more vivid colors.
Perfect view with non-glare display
The QMR series features reliable, non-glare panels that provide better visibility from all angles, anytime of day allowing businesses to deliver accurate information 24/7 in locations where clear and accurate information is crucial such as airports and commuter stations.
Slim and symmetrical design
The QMR series features a symmetric design simplifying wall mounting and ensuring installation is seamless. The flat back and slim depth will ensure a display that will stand the test of time.
Wi-Fi and Bluetooth built-in
Built-in Wi-Fi and Bluetooth allow for more personalized and interactive services as well as simplifying how businesses showcase content. Whether it's to make networking simpler or enabling interactive beacon technology in-store, QMR series displays help businesses move into the future of retail.
Samsung QM55R QMR Series - 55" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Platform
Tizen OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HDR10+
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN, Bluetooth
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Picture Enhancements
Mega Dynamic Contrast Ratio, UHD Upscaling, Dynamic Crystal Color
USB
2 ports
Voltage
Energy Class
Class G
143 Watt
Power Consumption (On mode)
108 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
158 kWh
123.51 cm x 4.63 cm x 70.79 cm
18.1 kg
Energy Class
Class G
143 Watt
108 W
108 kWh/1000h
158 kWh
Diagonal Class
55"
Commercial Use
Series
QMR Series
Platform
Tizen OS
Operating System
Tizen OS 4.0
HDR Capable
HDR Format
HDR10+
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Design
Narrow Bezel Design, Slim Design, New Edge Design
Dimensions
Without stand
123.51 cm
4.63 cm
70.79 cm
18.1 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Coating
Anti-glare, 0.25% Glass Haze
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
MagicInfo, Daisy Chain
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Connector Type
2 x HDMI input , DisplayPort input , DVI-Digital , 2 x USB , Audio line-in , Audio line-out , RS-232 input , RS-232 output , LAN , Infrared input
