Samsung's OL46B is an all-in-one outdoor display and enclosure designed to ensure flawless performance for outdoor high-impact business communications.
Samsung OL46B 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Remote control
Microsoft Certification
Compatible with Windows 7
395 Watt
Power Consumption Stand by
2 Watt
61.42 cm x 61.85 cm x 173 cm
395 Watt
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
61.42 cm
61.85 cm
173 cm
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
1500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Certified for 24/7 Continuous Operation
Stands & Mounts
Stand
Included
Stand Features
Swivel
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Connector Type
VGA input , DVI-D input , DisplayPort , Composite video input , HDMI , Audio line-in , Audio line-in , Audio line-out , Remote control , Remote control
VGA cable
