Samsung mono printer is designed for the modern office, combining flexible features that deliver speed, security, low cost of ownership and of course exceptional print quality.
Powerful dual core processors with Samsung's state-of-the-art System-On-Chip technology combined with a Gigabit LAN support enables large documents from multiple users to be received, processed and printed quickly.
Polymerized printing technology
Produce sharper images and lines, thanks to the unique polymerized toner particles. The format of the toner enables the printer to transfer the print onto the paper in a thinner layer, reducing waste and requiring a lower fusing temperature.
Impressive paper handling
The devices offers a wide range of paper handling capabilities, including duplex as standard, higher than average paper capacity, heavier media compatibility and full range of finishing options on the high volume printing devices.
State-of-the-art user interface
Easy-to-use LCD control panel and numeric keypad facilitates effective operation of the device to help promote secure and confidential printing.
Samsung ML-5515ND - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
34.8 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 52 ppm - B/W - A4 (210 x 297 mm) , Up to 55 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
Samsung 600 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, EPSON, PDF 1.7
UNIX, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.4 - 10.8
46.4 cm x 54 cm x 42 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.8 sec
Language Simulation
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
60 g/m² - 220 g/m²
Total Media Capacity
620 sheets
Media Feeders
1 x automatic - 520 sheets , 1 x manual - 100 sheets
Max Media Capacity
3660 sheets
Output Trays Capacity
500 sheets
Duty Cycle
Monthly Duty Cycle (max)
275000 impressions
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 10000 pages
Power supply
820 Watt
Power Consumption Stand by
100 Watt
Power Consumption Sleep
3.9 Watt
Software Included
Drivers & Utilities
