| Quicklinx: | 7M0VWS00 |
| Mfr#: | ML-4510ND/SEE |
Delivering a business print solution that answer both simplicity and productivity needs can be a challenge, especially across today's diverse business environment. With hassle-free integration and easy-to-use functionality, the Samsung Mono Laser Printer ML-5510 / 6510 series delivers amazing productivity. This is helped by the new larger paper capacity and the enhanced printing speeds. With the ML-5510ND, work will have never seemed so streamlined and efficient.
-High Performance Office Productivity
The ML-5510ND increases your productivity with a print speed of 52ppm in A4. If its breathtakingly fast printing speed isn't enough, when you factor in the processing power that comes with an 700MHz processor, Gigabit network and memory expandable up to 768MB,, there's no doubting the high-octane performance the ML-5510ND can bring to any office.
-Connectivity at the Touch of a Button
Connect everyone in your office to one network and keep everything running smoothly. They'll share a common printer and you'll save time from servicing multiple machines. And with the Gigabit LAN you can increase your performance by hooking it up to the network. Improve your communication skills with the ML-5510ND laser printer and keep your lines of communication open.
-Convenient One-Touch Eco Mode
One touch of the ECO button lets you print using less toner on each page to extend the life of toner cartridge and administrator can modify for more eco-friendly print setting for multiple pages per sheet and duplex mode with toner save mode. And it doesn't stop there. With the unique Result Simulator you can see exactly how much CO2, electricity and paper you have saved with the settings you've selected. Giving you real insight into the positive impact the Samsung ML-5510ND is having on your costs and the environment too .
-Totally adaptable, Easily Customisable
The Samsung ML-5510ND can be customised to suit your business needs. With a fully modular setup and plenty of expandability options, this printer meets the exact needs of your business.
-Maximum Paper Input
Feel free to multitask while your documents print: the ML-5510ND will crank through even your biggest print jobs without relying on you for a paper refill. Upgrade the standard 520-page capacity cassette and 100-page multi-purpose tray with 520-page optional second cassettes and 2000-page high capacity feeder for even larger capacity paper handling, perfect for all of your bulk printing needs. Sometimes, bigger really is better.
-One less noisy office distraction
You shouldn't have to struggle to hear yourself think while sitting at your own desk. That's why the Samsung ML-5510ND is engineered to be whisper quiet, generating a noise level of just 55 dBA while it's printing. That's less than the gentle hum of a running refrigerator! A desktop printer that does its work while letting you focus on yours? Cool.
- The printer that works with your budget
The ML-5510ND lets you choose the right consumables option which you can afford. Toner cartridges are available in cost-effective standard-yield 10000-page version and high yield 30000-page version which provide a lower cost per page and require fewer replacements.
