Enhance the look and sound of your TV with the sleek design of the curved soundbar. The distinctive curved design blends seamlessly with other equipment.
Enjoy a full, dynamic home audio experience with expanded depth and clarity.
Wireless active subwoofer
Feel the action of your favorite movies, shows and sports with dynamic, powerful bass for a lifelike home entertainment experience.
Bluetooth power on
Connect wirelessly for one-touch control of your soundbar from Bluetooth-compatible devices. Simply select the soundbar for pairing and power it on automatically for a seamless home entertainment experience.
Bass reflex subwoofer
Feel the full power of all your favorite movies and TV shows. Enhance your TV audio with built-in woofers, that produce a rich bass sound within the compact soundbar profile.
Surround sound expansion
Experience the full power and depth of your favorite movies and TV shows with a wholly optimized audio experience.
HDMI in/out
Enjoy your favorite movies, shows and sports with higher quality audio. The HDMI connection transmits digital video and audio over a single cable, delivering a superior entertainment experience.
Samsung HW-J6000R - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
300 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar 132 Watt 4 Ohm , 1 x subwoofer 168 Watt 3 Ohm
Speaker Details
Sound bar - stereo x 2 - 66 Watt - at 1 kHz - 10% THD - 4 Ohm - 2-way - active , Speaker - subwoofer - 168 Watt - at 100 Hz - 10% THD - 3 Ohm - active
Built-in Decoders
Dolby Digital, DTS decoder, SBC decoder, DTS Digital Surround
Sound Effects
Surround Sound Expansion
Power Options
Auto power on/off
Environmental Standards
ENERGY STAR Qualified
1-year warranty
USB-host
Enclosure Colour
Design Features
Curved
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
300 Watt
Amplifier
Integrated
Sound Effects
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Built-in Decoders
Audio Formats
Controls
Input selector, power on/off, volume
Speakers Included
1 x sound bar - 2-way - 132 Watt - 4 Ohm - wall-mountable / table-top - wired , 1 x subwoofer - 168 Watt - 3 Ohm - wireless
Speaker Details
Sound bar - stereo x 2 - 66 Watt - at 1 kHz CFR - 10% THD - 4 Ohm - 2-way - active , Speaker - subwoofer - 168 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
Driver Details
Subwoofer: subwoofer driver - 7"
Driver Details (2nd speaker)
Sound bar: 2 x tweeter driver , Sound bar: 4 x mid-range driver
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
AC power adaptor, remote control, CR2032 battery, power cable, wall mounting bracket
Sustainability Information
ENERGY STAR Certified
Power Source
AC power adapter
Options
Auto power on/off
Dimensions (WxDxH) / Weight Details
Sound bar: 1.078 m x 12.9 cm x 4.75 cm / 2.7 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
