Quicklinx: | GY50WS00 |
Mfr#: | SM-F721BZAGEUB |
Fits all your fits
The era of planning looks around your phone is over. Small but mighty when folded, Galaxy Z Flip4 is a compact full-sized smartphone, and just the right size to slip in a pocket when it's time to slay.
Holds up from flex to flat
The 6.7-inch display unfolds a beautiful view thanks to Ultra Thin Glass. Advanced durability makes it stronger than ever — staying tough through up to 200,000 folds.
Flippin' strong
From the inside out, Galaxy Z Flip4 is made to be durable. These are our toughest foldables ever with exclusive Corning® Gorilla® Glass Victus®+. And the hinge is protected by Armor Aluminum — our toughest aluminum frame.
Still unafraid of water
Water you worried about? These are the world’s first water-resistant foldable smartphones. It can hang out in 1.5 meters of water for up to 30 minutes without breaking a sweat.
MULTI-CAMERA SYSTEM
Live your best nightlife
The night just got brighter with Nightography on the Rear Camera. Details are brought to light even in the dark with bigger pixels on the Wide Camera. Say cheese!
Nightography isn't just for stills — it's also got video skills. When the action gets going, recordings stay smooth, not shaky, with enhanced OIS and VDIS. Powerful processing allows Super Night Solution to minimise noise so clips of the crew stay clear well into the night.
12MP Ultra Wide Camera
12MP Wide Camera
10MP Selfie Camera
Go ahead, flex on them
Introducing FlexCam, a versatile, hands-free camera experience. Take advantage of your phone’s agile angles to capture group shots, selfies and videos from mind-blowing perspectives and impressive true-to-life detail — even in your go-to social apps.
Enter your self-portrait era
Take selfies with the Rear Camera while the Cover Screen gives you a real-time preview. Check yourself from afar with a full-screen view finder, or tap to see the original ratio to make sure everyone is in frame. And with new software upgrades, Quick Shot is ready for even more action at all the angles between folded and FlexCam.
Power to the pocket
With this much juice, you can let every call go into overtime. An upgraded 4nm processor works with the long-lasting 3700mAh (typical) battery to power through the hours.
When it's low, plug in for Super Fast Charging or bypass the cord with Fast Wireless Charging 2.0. With all that power to spare, you can even share a charge with your friend or your earbuds with Wireless PowerShare.
Put your style on display
With a customisable 1.9-inch Cover Screen, you get yet another canvas to play with. Change it up as much as you want using your videos, photos or your own AR emoji to personalise the clock face. With this much control, you can easily update it with your mood, the weather or to match your outfits.
