| Quicklinx: | FBN0WS00 |
| Mfr#: | SM-G398FZKDU07 |
Fit for the great outdoors
Ruggedness and sophistication that go hand in hand. The slim 9.7mm Galaxy XCover 4s was made to handle rough conditions, and sticks with you when the going gets tough. Its non-slip finish keeps it snug in your hand even while on the go.
Durability for outdoor
Galaxy XCover 4s meets IP68 and MIL-STD 810G standards so it is durable enough to withstand harsh environments. Whether working in the field or manufacturing site troubleshooting problems it provides comfortable operation so you stay one step ahead of the job at hand.
Resolution that stands out
Get pristine viewing in all the places life takes you. The 5.0" high-resolution display on Galaxy XCover 4s delivers an optimal viewing experience for photos, maps and other visual content even when you're exploring off road, or out in the field.
Increased touch sensitivity
When business operations demand that gloves be worn at all times, the Galaxy XCover 4s ensures that the work gets done safely. Its increased screen sensitivity allows field engineers, factory workers and construction crews to keep projects running smoothly while protecting their hands.
Capture what's around you
High resolution to bring your surroundings into focus. The powerful 16MP rear camera captures the scene while the LED flash brightens up the space for shooting even in low-lit environments. Simply double click the home button for instant access and begin shooting.
Interchangeable battery
For workflows that demand extended functionality. The Galaxy XCover 4s is engineered with a powerful interchangeable 2,800 mAh battery. You can replace your battery and stay focused on your task for a long time while on business trips or in the field and unable to find a power source.
