The Samsung Galaxy Watch Active 2 is designed to help you learn more so you can achieve more. It goes beyond tracking steps and calories to offer actionable insights on everything from your running style to your heart rate.
Get more out of every movement with the Galaxy Watch Active 2. Its advanced sensors keep your pace on a jog, helping you better achieve your goals. It also automatically tracks your popular activities, from cycling to swimming, and lets you manually track other exercises.
Comfortably sleek
With a thin, light design, Galaxy Watch Active 2 is fit for any time and for any occasion, from working out to sleeping in. The AMOLED display is all screen from edge to edge. The touch bezel allows you to easily navigate with a quick turn, touch or tap.
Keep your beat
You can see if your heart rate is where you want it with Galaxy Watch Active 2. Get automatically alerted if your watch detects a high or a low heart rate.
Samsung Galaxy Watch Active 2 - aqua black aluminium - smart watch with band - aqua black - 4 GB
