That plus on the Galaxy Tab S8+ really adds up to something. You get everything on the Galaxy Tab S8, plus a bigger 12.4" sAMOLED screen. A bigger battery. And an on-screen fingerprint scanner. Built to take fun on the go.
The S Pen comes included and magnetically snaps to the back of Galaxy Tab S8+ to charge. Write, sketch, doodle or draw all your wildest ideas into reality with S Pen with ultra-low latency. A thousand tools in one, the S Pen gives you impressive levels of control.
It's tough, so creativity comes easy
The Armor Aluminum casing guards against all sorts of bumps and drops. The Galaxy Tab S8+ balances impressive durability with a super lightweight, slim design.
Ready for anything noteworthy
Samsung Notes is the quickest way to jot down all your brilliant million dollar ideas in an instant. It can do it all: memos, sketches, drawings - it can even turn handwriting into text to keep your ideas flowing.
Be the center of attention, wherever you are
The Dual Front Camera (Ultra Wide + Wide) boasts an impressive field of view that provides optimal 4K video recording.
Auto Framing
Auto Framing gives the spotlight the speaker deserves. So you can record a dance lesson and the camera will automatically zoom in to keep focus on you and your moves as you give instruction. The spotlight continues on video calls. When new friends join the call, the Dual Front Camera (Ultra Wide + Wide) even knows to automatically zoom out to include them, making it feel like you are talking to them in person.
Divide your screen, conquer your day
Size. Position. And number of windows. You're in charge with Multi Window. That means you can research decor inspirations, sketch out architectural plans, and video chat with your friend - all at once.
Lightweight but packed with fun
Stream all your favorite shows or movies from the comfort of your - well, wherever you want really. The vibrant display and enhanced bass create an immersive experience.
Ditch your gaming chair, keep the performance
Get console quality performance on the massive screen anywhere you want. And with the 120Hz display, everything runs smoothly for you to be on the leaderboard in no time.
Ready for anything
Experience lightning fast speeds on your various action-packed games and editing software with the 4nm mobile processor - the Snapdragon 8 Gen 1 Mobile Platform.
Fast connect to productivity
Galaxy Tab S8 Series has Wi-Fi 6E. You've got an incredibly fast Wi-Fi connection to boost your productivity. Share files between your Galaxy devices with speeds of up to 2.4Gbps.
