The beauty of what was engineered is to give you the slimmest feel in your hand without compromising the big screen size. And the elegantly curved front and back fit in your palm just right. It's as beautiful to look at, as it is to use.
Camera
Some of the most precious memories happen after dark. And this is the first smartphone camera to have a professional-grade Dual Pixel Sensor with which you'll now be able to take crisp, clear photos in the dark. With Galaxy S7 edge, you own the night.
Gaming
Mobile gaming just got a whole lot better with a dedicated game control center and gameplay recording. And with the Galaxy S7 edge's powerful processor, it just got highly realistic.
Hardware
The Galaxy S7 edge is redesigned to have memory that expands at your will. The incredibly fast processors and huge RAM keeps everything running smooth even when running at full capacity. While the bigger battery keeps you going for longer.
Water & dust resistance
The Galaxy S7 edge goes everywhere you go. In the rain, the shower, or the pool. Up to 30 minutes or 1.5 meters under. It is also worked out how to completely seal off the inside components while keeping micro USB ports, earphone jacks open, so you won't have to fiddle with extra caps or covers.
Shortcuts
Because you spend more time with the phones than ever before, you're constantly devising ways for you to get what you need at a touch and at a glance. And these shortcuts will get you everywhere.
OLED display - 2560 x 1440 pixels - 5.5" - 534 ppi - Quad HD Super AMOLED
Heart rate sensor
(8-core) - 64-bit
RAM 4 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 200 GB
Operating System
Android 6.0 (Marshmallow)
Main Camera
12 Megapixel - f/1.7 - focus: automatic
Front Camera
5 Megapixel - CMOS - wide-angle lens - f/1.7
Service Provider
Not specified
SIM Card
Nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Talk Time
Up to 1620 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, waterproof
Gold
72.6 mm x 7.7 mm x 150.9 mm
157 g
0.264 W/kg (head) , 0.507 W/kg (body)
Smartphone
Manufacturer Model Number
SM-G935F
Touch
Protection
Integrated Components
Heart rate sensor
72.6 mm
7.7 mm
150.9 mm
157 g
Body Colour
Gold
SAR Value
0.507 W/kg (body), 0.264 W/kg (head)
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Navigation
GPS, A-GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 38, Band 39, Band 40, Band 41
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
3600 mAh
Wireless Charging
WPC, PMA
Talk Time
1620 minutes
Run Time Details
Talk (WCDMA): up to 1620 min , Active online usage (WCDMA): up to 12 hrs , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 18 hrs , Playback (audio): up to 55 hrs
