The rear camera on the Galaxy J5 captures clear photos with enhanced detail in low light. Its intuitive interface enables one-handed functionality thanks to its moving shutter button, so you can still take the shot while adjusting your pose or framing the scene.
Look great in every frame
The Samsung Galaxy J5 lets you take bright and vivid selfies every time. Add more accurate detail into every low light shot thanks to its front LED and selfie flashes. You can also control the shutter with a simple hand gesture.
Full speed ahead
Keep usage running at optimal levels. The Samsung Galaxy J5 ensures highly responsive and blazingly-fast speeds to accelerate your workflow.
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
3000 mAh
Talk Time
1260 minutes
Run Time Details
Talk (WCDMA): up to 1260 min , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 13 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (video): up to 19 hrs , Playback (audio): up to 83 hrs
