The Samsung Fast Charge Portable Battery gives you additional charges to your smartphone. With Samsung Fast Charge, compatible devices can charge faster than standard USB charging options. You can charge your battery and phone at the same time with pass-through charging. Connect your phone to the portable battery, and then begin charging the battery. An LED power indicator shows just how much power is left in your portable battery.
