Now, the whole team can see perfectly. The IPS panel preserves color vividness and clarity across every inch of the screen. Work comfortably on the productivity-boosting wide display and see accurate tones and shades from 178° all around, with no color washing.
Designed for comfort
Swivel it, tilt it, pivot it. Adjustability features make your workspace even more versatile. Bring more style to your office with the sleek, clean design - VESA compatibility makes installation easy.
Ultra-smooth videos
AMD FreeSync plays videos without screen tearing, so nothing distracts you. Maximize your productivity and handle everyday tasks easily on the T40F.
See easily, achieve more
Protected eyes stay focused through the whole shift. Advanced eye comfort technology reduces eye strain for heightened concentration and greater productivity. Flicker Free technology continuously removes tiring and irritating screen flicker, while Eye Saver Mode minimizes blue light emissions.
Samsung F24T400FHR - T40F Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/406112
Energy Class
Class E
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
16 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Voltage
AC 120/230 V
54.77 cm x 22.4 cm x 37.64 cm
4 kg
3-year warranty
Display Type
Energy Class
Class E
23 kWh
Diagonal Size
24"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Wide Viewing Angle
54.77 cm x 22.4 cm x 37.64 cm - with stand
4 kg
VGA , HDMI
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Input Voltage
AC 120/230 V
16 W
16 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.77 cm - depth: 22.4 cm - height: 37.64 cm - weight: 4 kg , Without stand - width: 54.77 cm - depth: 4.06 cm - height: 32.07 cm - weight: 2.5 kg
