With an MTBF of 1,500,000 hours and a robust shock acceleration tolerance of 1500 g for non-operating conditions, this solid state drive offers exceptional durability and reliability for long-term use.
High-speed performance
Boasting an impressive internal data rate of up to 7450 MBps for reading and 6900 MBps for writing, alongside maximum 4KB random reads of 1600000 IOPS and writes of 1550000 IOPS, the Samsung 990 PRO ensures swift data access and transfer speeds.
Advanced security
Equipped with 256-bit AES hardware encryption and TCG Opal Encryption 2.0, this drive provides advanced security features to protect your data from unauthorized access.
Efficient power management
Featuring a low average power consumption of 6.5 W and an idle mode requiring only 55 mW, the Samsung 990 PRO is designed for efficient energy use without sacrificing performance.
Innovative technology
Incorporating Samsung V-NAND TLC Technology, Garbage Collection technology, and Device Sleep support, this SSD offers enhanced efficiency, reliability, and a high-capacity 4 TB storage with a 4 GB Low Power DDR4 SDRAM Cache for optimal performance.
TRIM support, Garbage Collection technology, Device Sleep support, Samsung V-NAND TLC Technology, 4 GB Low Power DDR4 SDRAM Cache, S.M.A.R.T.
25 mm x 80.15 mm x 8.88 mm
28 g
5-year warranty
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
Integrated Heatsink
M.2 2280
PCIe 4.0 x4 (NVMe)
25 mm
80.15 mm
8.88 mm
28 g
Performance
Internal Data Rate
7450 MBps (read) / 6900 MBps (write)
Maximum 4KB Random Write
1550000 IOPS
Maximum 4KB Random Read
1600000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
PCI Express 4.0 x4 (NVMe)
Compatible Bay
M.2 2280
Power Consumption
6.5 Watt (average) , 55 mW (idle)
Software Included
Samsung Magician Software
IEEE 1667
Limited warranty - 5 years / 2400 TBW
70 °C
Shock Tolerance (non-operating)
1500 g
