Quicklinx: | FQ58WS00 |
Mfr#: | QE55LS03RAUXXU |
A billion shades of colour - QLED Technology
Experience a billion shades of colour. With Samsung’s intelligent QLED technology, The Frame delivers 100% colour volume* that shows you realistic colours no matter how bright or dark the scene gets.
Experience exceptional picture detail like never before
Beautiful colour. Exceptional contrast. Impeccable detail. Discover what’s lurking in the shadows of a horror movie or witness the true beauty of a sun-filled landscape scene with HDR10+.
Customise to your style
The choice is yours when it comes to The Frame. Pick the ideal Frame for you home, style or artwork. The magnets make it simple to attach and detach the edges as often as your style changes.
Keeps the view clean
The One Near-Invisible Cable hides wires, so you can connect all your devices without any messy or tangled cables.
One Connect Box
The slim, One Near-Invisible cable connects every device to the TV through the One Connect Box. This way you place connected devices further away, freeing up space to upgrade your home décor.
Hangs like a real frame
Installing The Frame is simple and quick, and you can just tilt it sideways, back or forward for the ideal view. Gorgeous from all sides, it fits perfectly in your space.
Art Mode
You can customise The Frame to match your style so that you can enjoy the artwork or photography when the TV is off, instead of a blank screen. Simply select the art you want to show so your TV matches your style.
Frame your most-loved moments
You can easily upload and exhibit your own photography—or a new family portrait. Simply send your photos to The Frame TV via your phone or a USB flash drive.
Discover art from simple categories
Everyone can find the artwork they love. From colours to themes and much more, the simple and clear art categories of the Samsung Art Store make it fun and easy to discover a wide variety of art for all occasions.
The ideal way to appreciate art all day
By detecting the ambient light, the Brightness Sensor automatically balances the screen’s brightness and colour tone for a natural illumination. So whether its day or night, you can see your art as it was meant to be seen.
Motion Sensor
When you’re nearby, the Motion Sensor detects your presence and turns the TV display into artwork, so you can enjoy your favourite art while you’re there.
Easy to Use
Easily control all your connected devices and content with One Remote Control and your mobile. Adjust the settings or find new artwork to display. Easy to find, easy to use.
Control your TV with your voice
Flick through channels, see the weather or control smart devices by talking to your TV. Bixby lets you take control with your voice, making everything happen simply and in seconds.
Airplay 2 - With Airplay 2 built in, you can stream or share content from Apple devices to the big screen. Effortlessly play videos, music, photos and more from your iPhone, iPad and Mac on your The Frame.
Amazon Alexa - The Frame works with Alexa so your life just got simpler. It's easy to connect your Alexa-enabled devices. With The Frame's compatibility, have Alexa turn on your TV, change channels, control volume and more.
The Google Assistant - The Frame works with Google Assistant to make your life easier. Change channels, adjust the volume, control playback and more with just your voice.
