Discover the Samsung MUF-512DA, a USB flash drive designed to keep up with your active lifestyle. Offering 512 GB of storage capacity, it's suitable for storing all your important files, from high-resolution photos and videos to critical documents. It boasts a read rate of 400 MB/s thanks to its USB 3.2 Gen 1 / USB-C interface, ensuring that your data is always within quick reach.
Durability is at the core of the MUF-512DA's design. It's built to last, with resistance to water, shocks, X-rays, and extreme temperatures, making it your reliable companion in any environment. Whether you're at the office, on a construction site, or exploring the great outdoors, this flash drive is equipped to protect your data against the elements. Its compatibility is broad, meaning it works seamlessly with a wide range of devices, further enhancing its versatility as a storage solution.
