The Samsung 750 EVO boasts a fast random read/write (R/W) performance of up to 97K/88K Input/Output Operations Per Second (IOPS). With TurboWrite, write speeds for the 750 EVO are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at "After TurboWrite" speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads.
With no moving parts, the NAND flashbased 750 EVO provides superb durability and is lightweight, making it the ideal choice for working on the go. It is also shock and vibration resistant for worryfree operation.
Data security is of the utmost importance for businesses and personal PC use as well. The 750 EVO ensures it remains safe with Samsung SED technology. It includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption.
