With a color gamut of 99% sRGB (CIE 1931), the Samsung S32DM801UU delivers vivid and accurate colors, ideal for professionals who require color precision in their work.
Seamless connectivity
Equipped with HDMI and USB-C interfaces, along with a built-in USB 2.0/USB-C hub, this monitor offers versatile connectivity options for a streamlined workspace.
Ergonomic design
Featuring height, pivot, and tilt adjustments, the Samsung S32DM801UU ensures a comfortable viewing experience, allowing users to customize their viewing angle for optimal productivity.
Advanced HDR technology
HDR10 and HDR10+ support enables a wider range of colors and contrasts, providing a more dynamic and realistic viewing experience.
Smart features
From Adaptive Picture and Sound Pro to Smart TV capabilities and Samsung Knox Vault, this monitor is designed to enhance both your work efficiency and entertainment experience.
Samsung S32DM801UU - M80D Series - LED monitor - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1949502
Energy Class
Class F
Energy Consumption per Year
46 kWh
Wi-Fi, USB 2.0/USB-C hub, Bluetooth 5.2 adapter, USB PD 65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
400 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10, HDR10+
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, USB-C
Display Position Adjustments
Height, pivot (rotation), tilt
Voltage
AC 100-240 V
Warm white
71.34 cm x 20.01 cm x 61.62 cm
7.2 kg
CEC, HDCP 2.2
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class F
Energy Class (HDR)
Class G
46 kWh
Diagonal Size
32"
Operating System
Tizen
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
400 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10, HDR10+
Colour Support
1 billion colours
Colour Gamut
99% sRGB (CIE 1931)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Eye Saver Mode, Flicker Free technology, Image Size, Virtual AIM Point, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Gaming Hub, Game bar, Tap View, far-field voice interaction, Workspace, MultiView, Smart Calibration, My Contents, Nifty Gateway, Factory Tunning, IoT Hub, game mode, Smart TV, Sound Mirroring, Samsung Knox Vault, Remote Access, Adaptive Sound Pro, Active Voice Amplifier Pro, AI upscaling
Warm white
71.34 cm x 20.01 cm x 61.62 cm - with stand
7.2 kg
Audio
Speakers
Output Power / Channel
10 Watt
HDMI (HDCP 2.2) , USB-C (HDCP 2.2 / power up to 65W) , 2 x USB 2.0
Mechanical
Tilt Angle
-2/+15
Rotation Angle
184
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Screen mirroring, Samsung DeX
Remote control, SlimFit Camera
1 x HDMI cable ¦ 1 x USB-C cable
CEC, HDCP 2.2
Input Voltage
AC 100-240 V
31 kWh/1000h
Power Consumption HDR (On mode)
72 kWh/1000h
Power Consumption (Typical)
31.4 Watt
Power Consumption (Max)
140 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Bixby Voice Assistant, Microsoft 365, Alexa, SmartThings, Samsung TV Plus
Dimensions & Weight Details
With stand - width: 71.34 cm - depth: 20.01 cm - height: 61.62 cm - weight: 7.2 kg , Without stand - width: 71.34 cm - depth: 2.45 cm - height: 42.38 cm - weight: 4.2 kg
Shipping Width
92.5 cm
Shipping Depth
48.5 cm
Shipping Height
13.2 cm
Shipping Weight
10.4 kg
10 °C
10 - 80% (non-condensing)
